* @file path_planning.c
* @brief This file provides code for the path_planning of Rc2024 ,
* the R1 pick the ball,based on Dijkstra's algorithm function
* @author PanDezhi
* @Date 2023.10.12
* @attention
* struct Item {
* uint8_t number; // Number of each grain
* double distance; // distance for caculation
* enum Status status; // state taken or not_taken
* enum BallColor color; // full or none
* uint8_t init_distance; // Distance from starting point
* uint8_t total_distance; // shortest distance of path
* uint8_t total_order[12]; // shortest path
* int main
* struct Item result = Path_all(num); //the full grain u want to pick
* while{}
* O O O O O O
* L K J I H G
* O O O O O O
* F E D C B A
#include "path_planning.h"
#include "main.h"
#include <stdlib.h> // for qsort
#include <stdio.h>
#include <stdbool.h>
#include <limits.h>
uint8_t source; //The source point in the algorithm, i.e. the starting point
uint8_t V=12; // Number of vertices in the graph
uint8_t init_distance[12]={0,0,0,0,0,0,0,0,0,0,0,0}; //The distance between each point and the slope of Zone 1 and Zone 2
//The graph in the algorithm, the relationship between each point and the point it can reach
// A B C D E F G H I J K L
uint8_t graph[12][12] = {
{0, 1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0}, // Distances from A to other
{1, 0, 1, 0, 0, 0, 0, 1, 0, 0, 0, 0}, // B
{0, 1, 0, 1, 0, 0, 0, 0, 1, 0, 0, 0}, // C
{0, 0, 1, 0, 1, 0, 0, 0, 0, 1, 0, 0}, // D
{0, 0, 0, 1, 0, 1, 0, 0, 0, 0, 1, 0}, // E
{0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 1}, // F
{1, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0}, // G
{0, 1, 0, 0, 0, 0, 1, 0, 1, 0, 0, 0}, // H
{0, 0, 1, 0, 0, 0, 0, 1, 0, 1, 0, 0}, // I
{0, 0, 0, 1, 0, 0, 0, 0, 1, 0, 1, 0}, // J
{0, 0, 0, 0, 1, 0, 0, 0, 0, 1, 0, 1}, // K
{0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1, 0}, // L
//The initial state of each grain
struct Item Grain_init[12] = {
{1, 0, NOT_TAKEN, PURPLE, 0, 0},
{2, 0, NOT_TAKEN, Full, 0, 0},
{3, 0, NOT_TAKEN, PURPLE, 0, 0},
{4, 0, NOT_TAKEN, Full, 0, 0},
{5, 0, NOT_TAKEN, PURPLE, 0, 0},
{6, 0, NOT_TAKEN, Full, 0, 0},
{7, 0, NOT_TAKEN, Full, 0, 0},
{8, 0, NOT_TAKEN, PURPLE, 0, 0},
{9, 0, NOT_TAKEN, PURPLE, 0, 0},
{10, 0, NOT_TAKEN, Full, 0, 0},
{11, 0, NOT_TAKEN, Full, 0, 0},
{12, 0, NOT_TAKEN, PURPLE, 0, 0}
struct Item Grain[12]; //caculate
struct Item Empty_Grain[6]; //Store empty valley information
struct Item Full_Grain[6]; //Store Full valley information
struct Item Total_distance[6]; //Six empty valleys corresponding to the path
int Empty_index = 0;
int Full_index = 0;
*@ name : Givecolor
*@ function: Vision gives data
*@ input : none
*@ output : none
int Givecolor()
*@ name : compare_single
*@ function: Sort distance in an array in ascending order
*@ input : none
*@ output : none
int compare_single(const void *a, const void *b) {
double dist_a = ((struct Item *)a)->distance;
double dist_b = ((struct Item *)b)->distance;
return (dist_a > dist_b) - (dist_a < dist_b);
*@ name : compare_total
*@ function: Sort total_distance in an array in ascending order
*@ input : none
*@ output : none
int compare_total(const void *a, const void *b) {
double dist_a = ((struct Item *)a)->total_distance;
double dist_b = ((struct Item *)b)->total_distance;
*@ name : minDistance
*@ function: Function to find the vertex with the minimum distance value
*@param dist Array storing the distances from the source vertex
* to each vertex.
*@param sptSet Boolean array indicating whether a vertex is
* included in the shortest path tree.
*@ output : The index of the vertex with the minimum distance value
* among those not included.
int minDistance(int dist[], bool sptSet[]) {
int min = INT_MAX, min_index;
for (int v = 0; v < V; v++) {
if (!sptSet[v] && dist[v] < min) {
min = dist[v];
min_index = v;
return min_index;
*@ name : printSolution
*@ function: Function to prints the shortest path distance from
*@ the source node to each vertex
*@ input : none
*@ output : none
void printSolution(int dist[],int V) {
printf("Vertex Shortest Distance\n");
for (int i = 0; i < V; i++) {
printf("%d %d\n", i, dist[i]);
Grain[i].distance=dist[i];
*@ name : dijkstra
*@ function: Dijkstra's algorithm function
*@ input : src point
*@ output : none
void dijkstra(int src) {
src=src-1;
int dist[V]; // Stores the shortest distance from the source to each vertex
bool sptSet[V]; // If a vertex is included in the shortest path tree, sptSet[i] is true
// Initialize all distances as INFINITE and all vertices as not in the shortest path tree
dist[i] = INT_MAX;
sptSet[i] = false;
// Distance from the source vertex to itself is always 0
dist[src] = 0;
// Find the shortest path for all vertices
for (int count = 0; count < V - 1; count++) {
int u = minDistance(dist, sptSet);
sptSet[u] = true;
// Update distances of adjacent vertices of the picked vertex
if (!sptSet[v] && graph[u][v] && dist[u] != INT_MAX && dist[u] + graph[u][v] < dist[v]) {
dist[v] = dist[u] + graph[u][v];
// Print the shortest path
printSolution(dist, V);
*@ name : color_grouping
*@ function: Classify grain
*@ input : none
*@ output : none
void color_grouping()
for (int i = 0; i < 12; i++)
if (Grain[i].color == PURPLE&&Grain[i].status == NOT_TAKEN)
Empty_Grain[Empty_index++] = Grain[i];
if (Grain[i].color == Full&&Grain[i].status == NOT_TAKEN)
Full_Grain[Full_index++] = Grain[i];
*@ name : sort_distance
*@ function: ascending array
*@ input : none
*@ output : none
void sort_distance()
qsort(Empty_Grain, Empty_index, sizeof(struct Item), compare_single);
qsort(Full_Grain, Full_index, sizeof(struct Item), compare_single);
*@ name : Path_single
*@ function: Compute the shortest path to the source point
*@ input : the number of full_grain u want to pick and the source point
*@ output : none
void Path_single(int num,int src)
// Define and initialize variables
int choose=2*num; // Choice variable for alternating between empty and full grains
int source=0;
source=src;
for(int i=0;i<2*num;i++)
//initialization
Grain[source-1].total_distance += Grain[src-1].init_distance;
dijkstra(src);
color_grouping();
sort_distance();
// alternately selected
if(choose % 2 == 0)
Grain[source-1].total_order[i]=Empty_Grain[0].number;
Grain[Grain[source-1].total_order[i]-1].status = TAKEN; //refresh the status of Grain
src=Empty_Grain[0].number; //refresh the source
Grain[source-1].total_distance += Empty_Grain[0].distance; //refresh the total_distance
else
Grain[source-1].total_order[i]=Full_Grain[0].number;
src =Full_Grain[0].number;
Grain[source-1].total_distance += Full_Grain[0].distance;
Empty_index=0;
Full_index=0;
choose --;
*@ name : Item Path_all
*@ function: Find the shortest path to all points
*@ output : Each piece of information about the starting
*@ point of the shortest path (stored in a structure)
struct Item Path_all(int num)
int Full_num[6];
int index=0;
//Make sure the first one takes the empty valley.
for(int i=0;i < 12; i++)
if(Grain_init[i].color==PURPLE)
Full_num[index++]=Grain_init[i].number;
for(int i=0;i < 6; i++)
//Initialize Compute Structure
Grain[i] = Grain_init[i];
//Caculation
Path_single(num,Full_num[i]);
Total_distance[i] = Grain[Full_num[i]-1];
//Sort total distance of all Grain
int size = sizeof(Total_distance) / sizeof(Total_distance[0]);
qsort(Total_distance, size, sizeof(struct Item), compare_total);
//return the shortest distance grain
return Total_distance[0];
